Thread: New guy looking at liquidator!
    May 2013
    York, Pennsylvania
    29
    I stumbled across the liquidator shorty after joining this very informative site . I have been calling my local pool places all day and all of them but one get snippy with me when i mentioned liquid chlorine. None of them even heard of the product. The reason i called around was to see if they were familiar with the product and if they installed any prior. I simply dont trust myself with anything related to plumbing. Im going to attempt to post a pic of my setup and i appologize if it doesnt load.
    The pipe that is laying across the concrete is my temp return line because i have a leak in the return lines under the concrete. So that wont be fixed until august. Dont even get me started on the cost to fix lol. Im just wondering with this setup which is much less pretty than alot of peoples on here, if its possible to hook a liquidator up. There is a drain plug on the back and right behind the filter basket. Or in front im not sure. Me and my wife just bought the house a little over a month ago so it wasnt us who had them plumb it the way they did lol. Thanks for your time
    16x32 vinyl in-ground pool.
    Approx 21,000 gallons.
    Hayward DE EC65 filter and Hayward super pump.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: New guy looking at liquidator!
    [youtube:351u0xgq]P1UMoZHwWjk[/youtube:351u0xgq]
    Looks like you might need to install some longer stubs to drill through. Unless you don't mind drilling through the elbows.
    Mar 2007
    Virginia Beach
    272
    For the water outflow, you can almost certainly use the pump drain plug. You need to purchases an adapter from H.D. to do so. For the inflow side the logical place to put it would be on the temporary pipe run going back to the pool a few inches past the 90. That is flex PVC though and I have seen mixed results with the hose clamp working on flex. If it were me, I would give it a shot and if it didn't work, I would cut that section of flex out if it leaked and replace it with a small run of hard pipe and redo it.
    6000 gal inground fiberglass
    1.5hp pump / sand filter
    Liquidator
    May 2013
    York, Pennsylvania
    29
    Thanks for the replies . Well the flex section across the concrete is only temporary until august. Id prolly wait until all the concrete work is done and my return lines are replaced.
