Thread: My crystal clear pool!
    Apr 2013
    Eatonton Georgia
    145
    Been a bit of a rough go at times since I started opening the pool this year. It had not been covered and was green swamp. Moreover, nothing I tried that had worked in the past was working now. I had bought an Intex SWG hoping that would help but no way it was going to do it alone. After a partial water change and a lot of bleach, I got the pool to start clearing. Then I did a little work with borax for the PH and played with the stabilizer level a bit ( it was way low after the water change). The final step, even though it's frowned on around here was the addition of a small dose of water clarifier. The result is pictured below. Got a little more work to do with the vacuum but I'm pretty happy right now. Chlorine, PH and TA levels are stable and the water is as clear as I can remember.
    Regards,
    Michael
    18ft. diameter, 48 inch deep Sharkline Reprieve AGP, 7000 gallons, Intex 14 inch sand filter with 3/4 H.P. 2,150 GPH pump, Intex SWG
    TF-100 test kit
    May 2012
    Northern Connecticut
    103
    Re: My crystal clear pool!
    Nice!
    24,000 20x42 double roman end in ground pool being built. Start date june13, 2012.
    Finished July 4th, 2012, sports pool, vinyl,SWG, DE filter, fountains. Heat pump,
    First Pool Ever!
    Apr 2013
    Eatonton Georgia
    145
    Quote Originally Posted by Blessedwithfivekids
    Nice!
    Thank you. Now if it would just warm up enough to swim. Crazy weather here in Georgia. We are just now getting warmer temps.
    Michael
    TF-100 test kit
    Nice!!! We're also in GA.....disappointing temperatures so far!
    Normally by now, the pool's 85-90.....right now, it's a pathetic 78....
    Ok when the family comes to visit from England.....but far too cold for us oldies.....we're fair-weather swimmers!
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
