Results 1 to 10 of 10
Thread: Floating vinyl liner
    May 2013
    New Jersey
    28
    Looking for help before my husband looses it!
    We had a new liner installed in our pool last summer , we never covered it all winter, sigh. So instead of just removing leaves and shocking etc., my hubby decided to empty the pool. So we are now empty and the liner seems to be "floating" on the deep end. We thought vacuuming under the liner with a shop vac the adding water, like the pool guys did last year, would work? Any suggestions or help is greatly appreciated! Also, we have a smaller shop vac we hooked up under the liner ,we turned it off because it didn't seem like it was doing much. I was thinking maybe we needed a stronger shop vac? Thanks in advance!!
    IG pool with vinyl liner , appx. 20,000 gallons, Hayward Pro-Series S-244T filter, Hayward pump
    That's about all we know about our pool we just bought our house last year.
    31,500 gallon IG w/vinyl liner, Hayward Pro Series S-244T Sand Filter w/ 1hp Hayward pump
    TF-100 Test Kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Floating vinyl liner
    It's floating because there is ground water under it. You probably won't be able to vacuum it down until you either pump the ground water out or let the ground dry. When you add the new water, it will push the water out from behind the liner, but it can be difficult to get things smooth that way.
    This is the very reason we recommend against draining a pool unless you have to. Hindsight is 20/20 though.
    May 2013
    New Jersey
    28
    Thanks for your quick reply! So should we go ahead and start filling the pool back up? Or wait a few days and try to vacuum again? Thanks again!
    TF-100 Test Kit
    SW Indiana
    9,199
    Not an easy answer. What's the forecast?
    May 2013
    New Jersey
    28
    Besides a slight chance of passing thunderstorms tommorrow, the 5 day looks pretty dry.
    TF-100 Test Kit
    May 2013
    New Jersey
    28
    Here's a photo of the pool today.
    TF-100 Test Kit
    Apr 2013
    Central Massachusetts
    174
    Is there any harm is trying to add water to the pool other than having to drain it out again to let a professional smoothe out the wrinkles? They might get lucky and get a satisfactory smoothness by adding water.
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
    SW Indiana
    9,199
    Quote Originally Posted by MassNerd
    Probably no harm. Give it a shot and see how it goes.
    May 2013
    New Jersey
    28
    Thanks for the responses everyone! We started filling the pool yesterday just hoping for the best. This morning we are quite full , there's about 3" in the shallow end, and the liner is pushed back in place! There are 2 small wrinkles in the shallow end about 8-10" each. We're really not that concerned about them my husband got one out by gently tugging at the liner. We are quite happy at this point however, I know it could have been worse! I will know search this forum for suggestions on a good safety cover fir the fall lol! We are also going BBB and I just ordered my TF kit, thanks to this site. Thanks again!!
    TF-100 Test Kit
    May 2013
    New Jersey
    28
    *now * for ... I guess I should spell check !
    TF-100 Test Kit
