Thread: Plastica solar pool heating kits...(Maybe Sunheater?)
    Does anyone have any experience with these??
    Tom
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Plastica solar pool heating kits...
    Are you referring to the panels or the pods?
    Panels I think. Specifically these ones... http://bit.ly/17Rviw3
    Wanted to get some guidance before buying them.
    SW Indiana
    9,199
    I believe they are marketed in the US as Sunheater panels. http://www.bestbuypoolsupply.com/sunheaterag.html
    You might try search for that brand on here.
    EDIT: I edited the topic title to hopefully attract comments from people with Sunheater panels.
    Re: Plastica solar pool heating kits...(Maybe Sunheater?)
    Thanks John.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    John, may be right about the panels being marketed under the Sunheater name in the US, but I would advise caution in making that assumption, while researching various panels for my solar heat project I found at least a couple of brands of panels that looked nearly identical, but were substantially different upon closer inspection, they both used the banks of flexible tubes like the one you are considering, and likely used the same 3rd party header pipe, but the tubing sections were made of different materials, and on company glued the tubes on while the other sonically welded them. (tube material for the other one was not compatible with sonic welding)
    Ike
