Thread: OTO Chlorine test
    OTO Chlorine test
    In looking at the two recommended test kits (TF-100 and K-2006), the K-2006 does not have the OTO chlorine test. What do you need the OTO test (total chlorine?) for, if you can test the FC and CC? Thanks for the info...
    Houston Area
    33' dia AG, 24k gallons
    2 hp pump, Sand Filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: OTO Chlorine test
    The OTO test is cheaper and faster to run. It's fine for daily checks and as a backup when shock levels can cause you to question what is going on with the FAS-DPD test.
    The TF-100 ends up being a better value because you get the OTO and the larger sizes in the other tests.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Quote Originally Posted by AnneH
    The OTO test also never bleaches out. If FC is above the test range, it goes through shades of orange and brown. The DPD test can bleach out at super high FC and mislead you. You don't really need either of them with the FAS-DPD test, but since they don't make a pH test block without FC on the other side, you might as well have the better one.
    Jun 2007
    New Jersey
    653
    Quote Originally Posted by Richard320
    May I have the pleasure of introducing you to Taylor Part # 9058?:
    I don't have any OTO equipment any more and I don't miss it. (I used to use it for decades when it was the only test available.) I still have the DPD stuff that came with my original K-2000 Taylor (long since upgraded to a hybrid K-2006 with TFT CYA test), and I never use that either. FAS-DPD is all I need.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Thank-you!
    Houston Area
