Thread: Planning on opening pool. FC=0, PH 7.2, CYA <20 T/A=20
    Aug 2011
    Mechanicsburg, PA
    40
    I lift the cover today and got water sample.
    Salt water pool.
    Water looks ok, some leaves but color is ok.
    SHould I dump bleach to raise FC to 3.0 and start the pump before I do anything else?
    IG double roman vinyl 40x20. 35000 gal. 9' deep. Diving board.Pentair 400HD gas heater, ItelliFlow Variable Flow pump, 520 cartridge filter, two pentair G5 lights, IC60 SWG cell.
    Photo album: http://slava.no-ip.org/~poolpic/photo
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,013
    Re: Planning on opening pool. FC=0, PH 7.2, CYA <20 T/A=20
    Quote Originally Posted by slavka001
    Salt water pool.
    I'd start the pump first and be sure there were no leaks that would cause the loss of any chlorine you just poured in. If it's holding, sure, add some bleach. While it's all mixing, scoop out as much debris as you can. Then take another set of readings with everything all stirred up and go from there.
