Thread: New Build FC=0
    Jul 2012
    Southeast PA
    35
    New Build FC=0
    I am on day 10 after start up of a new build. Water looks clear, no CC smell, problem is... i can't get the chlorine to read above .5 . I am using trichlor to start with, so CYA is getting added slowly. I doubled the recommended flow through the chlorinator but still no budge... does the sun consume chlorine that fast without CYA?
    FC - .5
    CC - .5
    PH - 7.2
    TA - 80
    CH - 190
    CYA - 10
    I am supposed to balance the water in 3 days to "in season" levels... should i wait that long before adding bleach?
    600 sq. ft. 18'3" X 40'0" 25K gal Gunite Pool
    1&1/2 HP pump, 48 S.F D.E filter, Polaris 360 cleaning robot
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: New Build FC=0
    Yes it does. Add some liquid chlorine to the pool to get your chlorine up where is should be.
    Jul 2012
    Southeast PA
    35
    Re: New Build FC=0
    Done and done.
    You guys are awesome!
    Thanks JohnT!
