Results 1 to 13 of 13
Thread: SWG Replacement - Any suggestion?
    Hi friends,
    My Resillience/Aquacomfort SWG seems to be that it died after 3 years of work. (Aquacomfort just sent me a new cell last month) but my new problem is with the control box now...
    They now claim that they are not manufacturing those control boxes any more and I have just hated their customer support. Therefore I am now seeking for a SWG alternative/ different manufacturer... I have a 15k gunite pool and since I live in PR I have my pool open all year long. I run a 2 speed pump for 8 hours daily and my current chlorinator does not has a problem with running on low.
    Any suggestions?
    I started to do some shopping and read that the HAYWARD AQUATROL HP has lots of positive feedback; (Even tough it is desiged for Above Ground pools)...
    I just want to make a good decisions before making the purchase;
    thanks in advance!
    38,371
    Re: SWG Replacement - Any suggestion?
    If you want to look at Hayward, then get the larger Aquarite. Or check out Compupool which have gotten good reviews at a lower price.
    If is recommended to get a SWG cell that is sized for 1.5-3X the size of the pool, so I would look for something at least in the 25k size.
    Thanks for the advise Jason, Will do so...
    Please apologize my ignorance, therefore with SWG bigger means better? will it make a big difference if I choose the model for 40k gallons instead of 30k? My Pool is a little less thatn 15k gallons....
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    It just means the cell doesn't have to work as hard to keep up the FC. I have a 40k cell on a 11k pool, but that is really overkill. I think the 30 or 40 would both work well for you.
    38,371
    Well, not necessarily "better".
    Generally the cell rating is based on if the cell and pump ran 24/7 ... but we do not want to run the pumps anywhere near that long usually. So with a larger rated cell, we can run the pump for shorter periods of time and have the cells running at lower settings to produce the same amount of FC.
    Also, the cells generally have a life for running #,000 hours, well the fewer "on" hours each day, the longer the cell should last assuming you keep the chemistry correct. The larger systems and cells cost more $ upfront, but the belief is that it should last longer enough to make it worth the extra money.
    I would certainly consider a 40k cell for a 15k pool. I will have a 40k cell on my 18k pool.
    Great! thanks for the tip! I run my pump for 8 hours... I wish electricity woun't be @ $0.35 Kwh!
    One other question; does the temperature affects the cell? I ask, bcz we have a Solar heating system and our water ranges from 88-93 degrees; I will like to know if running this water trough the cell will affect its performance?
    38,371
    Don't think so. They work on hot tubs as well. They will turn off at low temperatures though (50-60).
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Thanks!
    raised the question, because manufacturer asked me at what temp. was the pool...
    Ok; After following daily with Aquacomfort, they have determined that the problem I have is with the control box. They are willing to offer a replacement controller at a "discounted" price of $650.00. I am very unsatisfied with their customer service; it took me more than 2 months to get a replacement cell under warranty (I had to purchase a new one and they made a credit once they received the defective cell) now a little after two years of service they are not willing to honor the warranty becuase they don't give support to outside of the continental 48 states....
    I paid $1600 for this system installed and only lasted 2yrs and 3 months...
    I am wondering that due to the fact that the cell is practically new (1month old) if someone can advise a place that I can sell this to and at least minimize the impact in the purchase of a new salt system (it will not be Aquacomfort for sure
    suggestions?
    JoshU's Avatar
    New Orleans, LA
    543
    Quote Originally Posted by rodneygranell
    eBay is probably your best bet for selling the old cell.
    I'm partial to AutoPilot products however we don't have distribution rights outside of the continental US. If you send me an e-mail I can forward your info to the proper contact within AutoPilot for international sales.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Thanks Josh,
    That was my bad; when I had the pool built I was offered a "Salt" system... I am not aware were the installer got the Salt cell since he didn't provided documentation... now the pool builder went out of business... therefore I am more inclined in getting a new system since I think I am done dealing with Aquacomfort... no email responses, very poor customer support.
    I am more inclined for a compupool system and just get rid of the old system....
    Thanks for the advise, I will be posting in ebay the cell once I got the new system installed...
