Results 1 to 17 of 17
Thread: I don't think it's algae - the local pool store does
    moze229's Avatar
    Jul 2011
    Central NC
    108
    I wanted to get this out here before I do anything. I've got something going on and I need help figuring it out. I had this happen a little last year but it wasn't as bad.
    Five days ago, I had what looked like algae at the bottom of the pool - little clusters of green patches. This is what I had last year that looked like algae, but it just turned out to be some sort of debris. It is not now, or ever been on the sides of the pool - only on the bottom. I assume it's some type of pollen. Anyway, I vacuumed most of it to waste. Some of it seems to be a little stubborn and didn't want to come off so I just brushed it into the water column assuming that the filter would catch it. When I did this, the water became cloudy. It was a white cloudy - not green. FC was at 6 - where I always keep it and I had no CC's so I was assured that it wasn't some kind of algae.
    Now I have a green cloudy water. Yesterday I brought it up to shock level using the charts here (I only use bleach - I'm using the BBB method) and tested last night and this morning. (My CYA is at about 40) I didn't loose any chlorine last night and I got a reading of zero CC's today and last night. I'm using the TFTest kits. Doesn't sound like algae to me.
    So, I called the local pool store and he told me that the pool probably had what was called a "chlorine lock" and I need to shock even higher. He then proceeded to tell me about all of these high-priced shock and algaecide products that he wanted to sell me. It all sounded foreign to me but before I do anything, I wanted to run it by the folks here to see what kind of reaction I get. I trust the advice here first.
    My theory is that it's likely pollen. I've had the pool open for a while now (not swimming yet) and the pool has pretty much been exposed to the entire heavy pollination season. Whatever it is, my sand filter is not pulling it out. If this is the case, besides adding a diatom setup, is there another way to filter this out?
    If there is anything else that you need to know, please ask.
    24' X 54" Sharkline Matrix AGP ~ 15,200 gallon
    1.5 HP Dynamo Dual Speed ran 24/7 at low speed w/250lb. SD60 Pentair Sand Filter
    Plumbed with PVC - buried.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: I don't think it's algae - the local pool store does
    Short answer: pool-school/add_de_to_a_sand_filter.
    It will filter down to about 4 microns, so do it on a day when you're around to keep an eye on the pressure, because it could load up in a hurry.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Trust your gut. No overnight loss its likely pollen. Pool store guy doesn't know what he's talking about.
    Try skimmer socks/nylon knee highs over your skimmer basket, a little DE in the filter couldn't hurt either, before and after you vacuum. If you vacuum to waste just do the DE after.
    moze229's Avatar
    Jul 2011
    Central NC
    108
    Just for illustrative purposes.
    [center:3733rx1y][/center:3733rx1y]
    Thanks for the ideas. I'll update as I progress along with this.
    moze229's Avatar
    Jul 2011
    Central NC
    108
    Just an update - I put a nylon sock over the skimmer basket and I've pulled a few baskets full of this soft whitish/green tree gunk out, so that's what it is. The pool doesn't look a whole lot clearer yet, but some.
    If I decide to buy the DE media, where is the best place to buy? It doesn't sound like I'll need all that much to add to my sand filter, and I think I've seen in it 25lb. bags.
    Richard320's Avatar
    Jan 2010
    19,075
    Quote Originally Posted by moze229
    I've seen it at Lowes. Of course a pool store will have it.
    30,432
    Algae can occur quite easily with no cc's.
    Did you perform the OCLT by following the instructions explicitly? The pic sure makes it look like algae but you should have a little chlorine loss overnight if it is (like FPM is saying)
    moze229's Avatar
    Jul 2011
    Central NC
    108
    It does look like algae, doesn't it?
    Thanks for the warning of no CC's not necessarily equalling no algae. However, I'm loosing no FC at night and the water is becoming clearer. Not only clearer, but it's not green anymore.
    I suppose that it still could be algae, and the water is clearer now from the initial shock that I did a couple of days ago. I'll keep an eye on it and keep changing my nylon sock and see where I end up.
    moze229's Avatar
    Jul 2011
    Central NC
    108
    And I should say that me saying no FC loss at night may not be entirely accurate. I'm just not testing sensitively enough to measure less than one PPM. But I suppose as long as its less than one i am still ok.
    Feb 2008
    Denton, TX
    5,061
    Well, if you are using the TF100 test kit and you're following the directions, you should be testing with a sensitivity of 0.5 ppm of FC per drop. That would yield a sensitivity of less than 1 ppm. You're right though in that as long as you lost no more than 1 ppm overnight, you're ok.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Stuff in filter looks like the pine tree pollen we get.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    moze229's Avatar
    Jul 2011
    Central NC
    108
    Quote Originally Posted by harleysilo
    Yeah. We had the pine trees pollen off a long time ago though. Aren't a lot of pine trees in this specific area, but that doesn't mean that it's not part of what I have going on. There are nothing but pine trees a few miles from here.
    Jul 2012
    Herndon, VA
    419
    You say "from the initial shock I did a couple of days ago". Makes it sound like you're not doing the shock as a process, instead are doing just a one time shock?
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    moze229's Avatar
    Jul 2011
    Central NC
    108
    Quote Originally Posted by GuinnessPhish
    No.
    I stopped the shock process once I referred to the people here and was reassured that algae was likely not my problem. Since I wasn't loosing any FC at night, I didn't have a way to continue shocking as a process. There was no process to follow.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    You got to keep pool at shock level till it meets all 3 criteria, the pool is not crystal clear is it?
    18'x43' Sport Pool
    moze229's Avatar
    Jul 2011
    Central NC
    108
    Algae isn't the problem!
    I actually ended up pulling most of the gunk out of the water (whatever it was) via nylon sock as suggested by frustratedpoolmom. I did not have algae. I repeat, there was no algae. The water is ALMOST crystal clear now. Next time I'll try some DE and it should go faster.
    Aug 2011
    Virginia Beach
    295
    Thanks for posting, especially with the pics. My pool looks the same, and I have the same symptoms. I'll do the OCLT tonight to verify, but my FC hasn't gotten away from me this year. I'll be looking for a nylon sock as well.
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
