Well I ordered a B2983T from Pool Supply World on Sunday. It arrived on Thursday and I installed it today. Very simple install. Just removed the old motor, connected the new motor using the same wiring, put the old impeller on the new motor, and put the whole thing back together. Probably took about an hour.
Since the controller is on the motor I removed the on/off pegs from my round Intermatic controller. I just leave it in the on position all the time so the motor controller always has power. I was running my old pump 7 hours/day so I set the new motor to run 14 hours on low speed.
I'm very impressed with how quiet the pump is now. Can't even hear it when sitting on the patio. Even when you stand right over it you will find it hard to hear. I even tried high speed and found it was quieter than my old motor. But I plan on just running it on low speed all the time.
After the change I did notice I have a small leak that I need to troubleshoot. I'm guessing I just don't have the band clamp that clamps the wet end to the motor end tight enough.
I also noticed my Pentair cartridge filter now runs at a very low pressure. I have a 60 psi gauge. Typically with clean filters I run at about 20 psi and have been running at 22 psi for the past month or so. Now running on low speed the gauge barely registers at around 4 psi. I expected the pressure to go down, but not that much. I may have to change out the gauge now so I get a more accurate reading to tell me when to clean the filters. Since I use a robot for vacuuming, I typically only need to clean my filters once year.
