Results 1 to 20 of 20
Thread: Hola from Phoenix
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Hola from Phoenix
    Hey everyone. Found the forum while trying to research what seems to be a mustard algae problem. My pool is 3 years old and starting to show signs of my not-so detailed care of it. I look forward to learning from all of you in the different topics.
    - Ryan
    Here are some pics:
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Hola from Phoenix
    Welcome to TFP!
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    30,403
    Welcome to the forum.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Welcome. Once you catch on to our philosophy, you'll find it takes less time and produces better results. Win-win!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Bienvenidos.
    Immerse yourself in Pool School. It will save you a lot of typing out questions.
    Hint: Look for symbol by thread titles - that means there's probably pictures to inspire you.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    fill out your sig so we know generally where you are located and all the info about your pool...post some pics of it too!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Hey guys, I filled out my sig to give some info on my pool. I'm trying to think of all info that would be pertinent. My pool has real boulders that line certain parts of the pool and the trim that over hangs is flagstone. Should I include that info in my sig to help diagnose any issues that I am having?
    Also, I added pics to my original post
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Modawg2k
    First thing if you do not have one already, is to get an appropriate test kit: http://www.troublefreepool.com/pool-...kit_comparison I like the tf-100 more reagents for the money.
    Your sig looks good.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    It's on order as we speak.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Modawg2k
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Modawg2k:
    Welcome to TFP
    Nice looking pool and backyard retreat with a nice view to top it off.
    Only thing I would add is SWG after the Pentair Intellichlor IC40. Just makes it that much easier for readers to see that it is a SWG pool.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Quote Originally Posted by BoDarville
    Modawg2k:
    Welcome to TFP
    Added, thanks!
    Welcome. Where at in phx? Im in chandler. See you an LS guy. I have a 12 CTS V my self.
    Feb 2008
    Denton, TX
    5,061
    What a beautiful pool!
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Quote Originally Posted by Heater
    You got it I live in north central phoenix. How's the city's water hardness effect you?
    As far as the pool or washing the V?
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Haha...... I guess the pool. I already know to wash out of the sunlight, and dry fast on the car.
    Well keep up on the calcium line is a pain. Haven't found anything to get it off the stone from the spa spillover. Can't complain I guess. Haha
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Besides high calcium, we can't forget this little gem that we deal with several times a summer....
  20. Back To Top    #20
    Oh yeah! Turns the pool to a mud pit quickly!
