Thread: Pump gurgling
    Pump gurgling
    Is it normal when opening the pump to clean the basket for water to go down below the the suction line of the pump and make a gurgling sound? The 3 way valve is off so water can not flow back into the pool also. Just noticed my ecostar done this earlier when cleaning out the strainer. It holds prime fine and there was no air bubbles before opening. Just didn't sound right.
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pump gurgling
    Normal. You are allowing air into the system and water runs out of the returns which pulls water out of the filter.
    Re: Pump gurgling
    Ok. Just don't remember it being that loud. Thanks for the quick reply.
