Thread: Need to reduce TA
    Michigan
    83
    Need to reduce TA
    Right now my pool is clear and per the simplepool android I need to reduce my TA and increase CYA. The simple pool application recommendation mirrors what pool school recommends. I never have had good luck reducing my TA but the pool school says this is a critical spec to maintain. Can anyone recommend a good way for me to reduce my TA ? I have a attached spill over SPA I could use to aerate a small portion of the water but nothing else.
    TC=5
    CC=0
    PH 7.6
    TA = 160
    CYA = 50
    CH=250
    salt=3300
    I do intend on adding CYA until I reach 75 per the pool school.
    20*40 Liner 2'-8' deep, Spill Over SPA, Electric Cover, Jandy Purelink (Aquapure & PDA), Hayward SP2610x15 (1.5HP Single Speed), Hayward H300 (Millavolt)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Need to reduce TA
    Just keep adjusting pH and TA should come down all by itself. All the aeration does is accelerate the pH rise so you can dose it with acid again a little sooner. Same amount of acid. just less time.
    The TA got there from your tap water. You've been drinking and bathing in the stuff for how long? It's not hazardous. Is the water clear and sparkly? Is it warm enough? Then go swimming! That will aerate it plenty.
    38,475
