Results 1 to 12 of 12
Thread: What size fitting for Hayward Union?
    Smykowski's Avatar
    Sep 2011
    3,065
    Because of leaks, I'm changing my setup. I've got a Hayward Power-Flo Matrix pump, and I'm attaching Hayward Unions to the pump discharge (the part# is SP1500UNPAK2). I've got 1.5" I.D. braided clear tubing between the pump and the filter, so I need a fitting to connect the union to the clear tube. What size is the male side of the Hayward union? And can I buy the fitting at a big box store, or is it going to be another "patented thread" from Hayward, so I'll have to buy something either online or from the pool store?
    38,354
    Re: What size fitting for Hayward Union?
    If I understand correctly, the union is designed to be screwed onto the pump and the other side "glued" to PVC pipe. So I would think you would just need to use solvent to attach the PVC pipe to the union and then use whatever PVC fitting you need to go to your flex hose.
    But, you are correct that the threaded part that attaches to the pump is likely proprietary.
    Smykowski's Avatar
    Sep 2011
    3,065
    That would be ideal. Here's a picture:
    http://www.poolpartsonline.com/p-41739- ... parts.aspx
    What I couldn't tell was if the side that was downstream of the pump had to be threaded, or if you could cement to the inside of the pipe.
    Put another way, is the downstream side of the Hayward Union designed to be the male end of the fitting, or the female end? Or can I do it either way?
    38,354
    I guess I do not know about those unions. The ones I have used allowed either a pipe to be glued inside, or the pipe was the same size and could be glued on with a coupler.
    Not sure what is supposed to be done with those threaded ones.
    Smykowski's Avatar
    Sep 2011
    3,065
    I guess I'll figure it out. I'm just hoping when I get this thing on Tuesday I can find a part locally. This waiting four days nonsense because I have to buy everything online is getting old.
    38,354
    It may just be a "normal" male PVC thread that you can get a PVC fitting to screw right on ... would not really make sense for that to also be proprietary when the pump side already is.
    Smykowski's Avatar
    Sep 2011
    3,065
    I wanted to update this thread in case anyone runs across it in the future.
    The pump side of the Hayward Union is the funky proprietary size thread. The other side of the union is just a female PVC fitting, which will accept a 1.5" pipe. It can also be a male threaded fitting, which I assume is a standard thread for a 1.5" fitting, but since I cemented the pipe and didn't use it, I'm not exactly sure.
    Orlando, FL
    690
    Thanks for the update. My Hayward pump arrived and I was a bit annoyed/perplexed to find that the fittings that I purchased would not fit. Your initial and updated postings helped me 1. realize I was not crazy, 2. informed me the inside of the connection on the pump is threaded, and 3. prevented me from making useless trips to the hardware store.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Smykowski's Avatar
    Sep 2011
    3,065
    Glad I could help.
    Jul 2017
    Colorado
    86
    Can you guys post an image of this connection? I'm dealing with the exact same thing now. Thanks.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Union Connector Kit (Nut, Connector, Gasket) | Hayward Residential and Commercial Pool Products
    It may be slightly different depending on which pump you are needing connectors for.
    Love TFP? Become a
    TFP Supporter!
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    The union connector kit for the Matrix pump is a SP1500UNPAK2
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
