Results 1 to 7 of 7
Thread: CYA Level with SWG and ORP
    acaciolo's Avatar
    Apr 2008
    Northest PA - Lehigh Valley
    75
    I just read 2 threads on the forum about CYA levels, and I am not sure which one to follow. 1 thread in the SWG set up advice sticky states to keep the CYA level high...between 60-80 in order to help preserve the cell.
    Another sticky about "what the measurements mean" states this:
    If you are using an ORP controller, keep CYA below 50.
    So...I am using the wonderful Autopilot total control systems, and I am not sure as to where to keep my CYA.
    I also added Borax this year...and it seems to have made my water "sparkle" and really, really cut down on my acid consumption!
    Thoughts?
    Owner of Monogram Custom Pools in NE PA. My Personal Pool - 1000sf gunite pebble pool with 1500 gallon spa/grotto and 500 gallon outdoor spa; Pentair i9 Intellitouch with i10x expansion panel. Screenlogic 2/iPhone
    Intelloflo SVRS main pump, 6 whisperflow pumps 2hp to 3hp, Intellichem system, ic60 salt water cell, Sta rite 400k btu heater, Pentair 120k btu heat pump
    Welcome to TFP!
    If you have the Total Control system, the ORP sensor will not work properly with CYA above 50. You should keep CYA around 30 to 50. This does result in more PH drift, but the Total Control system's PH regulation takes care of that for you. It also shortens the cell life a little, but the benefit of automation is worth it.
    Sep 2007
    Lafayette, Louisiana
    344
    Will the chlorine output still keep up with a CYA level that low for the SWCG?
    Jason,
    I read the review you made of the Total Control system and the ORP was not working for some reason. Did you get that problems solved?
    Fortune favors the well prepared
    The build...
    viewtopic.php?t=3974
    Freeform 24' x 38' IG gunite. 3 1/2' to 8' deep. 28,500 gallons. AutoPilot Total Control SWCG. Pentair Intelliflo VF. Pentair CCP520 cartridge filter. Colorlogic LED lights. Tahoe Blue Diamond Brite. 1200 sq ft stamped concrete deck.
    More details as they happen...
    No, my ORP sensor has never been useful. The best I can figure, about one in ten, or maybe slightly fewer, have the same problem I have. No one has ever found a solution that is even vaguely affordable, and even the expensive solutions aren't a sure thing. The big problem is that there doesn't seem to be any way to predict which pools will have problems with their ORP sensor. For outdoor pools it isn't a big deal, simple percentage control is just fine. Indoor pools have a more serious problem because percentage control isn't really good enough indoors.
    Because of the CYA limit, you need a larger cell with the Total Control system than you would need otherwise. However, AutoPilot is fairly conservative in their cell sizing guide so it is almost always fine.
    acaciolo's Avatar
    Apr 2008
    75
    odd
    This might explain why my orp sensor is givng such off readings. the odd thing is that autopilot specifically suggests a higher range of CYA (think they say 60 or 80-100) I am surprised that they would suggest a range that causes the orp sensor to be inaccurate. In the past, I have kept my CYA at 50...but I raised it this year (because of the post I saw on this forum about why to keep your CYA higher with salt water.) I also confirmed it with Autopilot and they agreed.
    I am going to ask my personal salt water guru (sean at autopilot) his thoughts as well.
    thanks.
    tony
    www.monogramcustomhomes.com
    If you read closely, AutoPilot recommends CYA between 60 and 80 except when using the ORP sensor in the Total Control system. With ORP they recommend CYA between 30 and 50.
    acaciolo's Avatar
    Apr 2008
    75
    I just checked my manual. Yup....cya of 60-80 but it "can be reduced" to 30-50 for the orp controller or cold climates.
    darn....
