Thread: Algae? Stain? with pictures
    Guest
    Recently, I noticed some brown spots on the floor of my pool. There a several of them, but not many.
    They can't be brushed off, and do not grow (yet) either.
    I have shocked my pool with FC15-17 last Sunday, and overnight is less than 0.5.
    current:
    FC: 5
    CC: 0
    pH: 7.6
    CH: 260
    CYA: 40 (just replaced 2/3 water last Saturday.)
    Borate: 0 (i guess, the test strips will be delivered tomorrow)
    Any ideas about what they are and how to remove them?
    Thank you in advance~
    Feb 2008
    Denton, TX
    5,061
    Re: Algae? Stain? with pictures
    Looks like metal stains. Here's how you can tell. Take a vitamin C tablet and scratch it on the stain. If it lightens, it's metal staining. If it doesn't, try taking a chlorine tablet and setting it on the spot for about 20 or 30 minutes. If it goes away then, it's organic and will disappear with proper chlorination; faster if you shock your pool.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Very good chance those are rust. Even the tiniest piece of steel can leave a mark. I had a few freckles after I had a fence replaced.
    Solution: Vitamin C tablets. I just bought the cheapest store brand. I smasked them into about quarters and stuck them in a nylon with some smooth rocks and tied a string to it. Then I set it on the spot. It might take some nudging with the pool brush to get it on the right spot. I just left it there overnight. Done.
    Guest
    thank you so much for you quick reply!
    I will try Vitamin C, and report results tomorrow
