Thread: New to Pools in Wisconsin
    May 2013
    Wisconsin
    5
    Been reading on the boards for a few weeks now.
    Just purchased a house with an 35,000 Gallon IG Vinyl pool.
    I never wanted a pool ,but it came with the house, so I'll learn to take care of it.
    Haven't received the test kit I ordered yet, but this should be a new experience.
    I saw the BOGO chlorine deal at Menards and picked up 7 cases.
    Not sure if that is enough for our pool season here, or If I should buy more.
    Haven't found a way to estimate annual chlorine usage yet and I probably won't be able to until I have a solid water measurement.
    I'll be seeing you all around.
    Milwaukee WI, USA
    35K gal IG vinyl, 1.0 HP Haywood pump
    Sta-Rite Cristal-Flo T-240BP-1 Sand Filter
    Polaris 380
    Feb 2008
    Denton, TX
    5,061
    Re: New to Pools in Wisconsin
    Welcome to TFP!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Thykon:
    Welcome to TFP
    Quote Originally Posted by Thykon
    I saw the BOGO chlorine deal at Menards and picked up 7 cases. Not sure if that is enough for our pool season here, or If I should buy more.
    That's the time to stock up - when it's on sale. As for whether it's enough for the season, it depends on how many oz. are in a case, what the chlorine strength is, and whether you need to shock the pool during the season.
    If you haven't opened the pool yet, I would do that soon - this weekend, if possible. While waiting for your test kit, clean out as much stuff from the pool as possible. Then run a series of tests once you get your test kit.
