Results 1 to 7 of 7
Thread: Can Quad DE be used without DE?
    Jul 2008
    Dallas, Tx
    128
    New pool being built. Quad DE filter. I have the spa full and would like to filter the spa so I can balance the water. I cannot charge the Quad DE until the pool is full and have access to the skimmers. Is it ok to run the filter without DE?
    20k white plaster with blue quartz, IntelliFlo VS, Quad DE 100
    1000 gal spa with natural stone waterfall
    Beach entry with 2 bubblers. Pool built Spring 2013
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Can Quad DE be used without DE?
    Not a good idea. The mesh that holds the DE will capture any particles in the water and clog, requiring disassembly to clean. You can run with the valve set to recirculate, which bypasses the filter.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    If you can shut off the skimmers, could DE be added (not all at once) through the pump basket?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jul 2008
    Dallas, Tx
    128
    Thanks for the replies.
    John, it's a Quad DE, did you catch that? No mesh (I don't think?) as it has cartridges. My first Quad DE so maybe I have no idea what I'm talking about. Also, no valve, yet. So recirculate, although a good thought, won't work.
    Harleysilo, maybe? I would need some more detailed instructions there. Anyone?
    SW Indiana
    9,198
    Quote Originally Posted by Terry
    Same issue with your cartidges. They have larger holes in them than a standard cartidge, and debris that normally wouldn't get past the DE can get lodged in the cartridge.
    From the manual:
    "Never operate filter in excess of three (3) minutes without use of diatomaceous earth. Diatomaceous earth
    is the substance that filters the water, the filter cloth merely supports the diatomaceous earth. Operating
    without diatomaceous earth will damage filter elements and shorten filtering cycles."
    Jul 2008
    Dallas, Tx
    128
    Thanks John. Will have to wait I suppose.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Okay so we know you can't run the filter without DE. The question is can you get DE into the filter without skimmer operation.
    So is everything set up to run both the pool and spa separately? I mean can you run your pump off of spa water only? Or will it always draw some water from the pool (skimmer and main drain)? IF you can just operate the spa only, then couldn't you add DE through spa drain? Obviously you would have to get the DE underwater near the drain, and risk it going everywhere in the spa.....
    If pump always pulls from pools drains and skimmer, can you shut off skimmer, such that it's only pulling water from drains?
    If you can shut off skimmer couldn't you add say 1lb. of DE at a time into pump basket and turn on for a few seconds, maybe 15-20. Then shut off, add another pound and repeat till you've added required amount?
    It is typically recommend for the DE to be added in/at the skimmer. Which may allow a nice long run to the pump before it hits the filter. I don't know how shortening that run via dumping in pump would affect the DE spreading out and covering all the grids evenly. That is the big question.
    18'x43' Sport Pool
