Thread: What do you use for a pump/filter pad?
    Jul 2012
    Chicago, IL
    356
    The pump/filter I inherited sat on a kind of flimsy piece of plastic that I would like to replace. Any good ideas out there, can I just set everything on some paver type stones? Any problems with vibration noise based on what it is set on top of? Hit me with your ideas please!
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    May 2012
    North of Charlotte, NC
    312
    Re: What do you use for a pump/filter pad?
    I've had great luck with a local HVAC supply house with getting a compressor pad made of composite....had quite a few different sizes as well 36x24 36x36 36x48 to name a few....all about 3" in height....very light and easy to work with...
    Here's mine as a work in progress.... 1 36x36 and 1 36x48
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Mine sits on a couple of 2x3 patio stones (similar to RoadKings), the filter is heavy enough that it dosn't need to be secured, the pump base has holes for screws, got a concrete bit and screws, no problems.
    From what I've seen I think this is a very typical AGP pump/filter set up.
    Jul 2012
    Chicago, IL
    356
    Thanks, I like the HVAC supply store idea.
    Cramar - I assume you don't experience any extra noise with the vibration on top of stone??
