Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: pump starts for a few seconds and automatically turns off
    Apr 2011
    Houston, TX, USA
    105
    hi all,
    my very old century centurion 1hp pump and it started giving me some problems today.
    basically, when I turn on the pump it stops a few seconds later (sometimes in 15 seconds). the pump simply turns off.
    also, when it starts, it is making a noise that is louder than usual.
    I am suspecting (without evidence) that either the shaft or the bearings are at fault here and the pump automatically shuts off itself to prevent overheating. however, during those few seconds, water is flowing through the pump and I can see the motor rod turning fine
    One other key thing to note. once it turns off you can't turn it on again right away. after a little bit of time, you can hear a clicking noise, and then the pump can turn on again. Obviously a few seconds later, it shuts off again.
    any ideas on what this might be or where to start? my pool is beautiful now and if I can't fix this soon, it will turn ugly soon
    14500 gallon plaster pool (replastered in May 2009) : 32ft.L x 4ft.D x 14ft.W
    Pentair FNS Plus 48 sqft DE filter
    Polaris 280 at 2hrs per day (retired now) & Aquabot T-Jet Turbo used as needed
    Circupool RJ30 SWG set at 80% output & Pentair SuperFlo 1hp 2speed running 6-8 hrs/day in the summer
    38,271
    Re: pump starts for a few seconds and automatically turns of
    Sounds like overheating. Check if the capacitors are still good, but if it is making a lot of noise, the bearings are likely the problem.
    Might want to consider ordering a new motor for the pump (like a 2-speed) or a whole new pump if you think the wet end is too old for some reason.
    Mine lasted a couple weeks after it started doing that cycling and then something happened to melt part of the inside of the motor.
    Apr 2011
    Houston, TX, USA
    105
    I wonder if it is economical to replace the entire motor vs getting a new pump. this pump is old for sure. would the capacitors still be the problem if the pump starts ok and runs and pushes water for 15 seconds?
    I started researching new pumps tonight and I am thinking of going with a Pentair SuperFlo 1.5hp 2 speed. I currently have 1hp, but I would go up to 1.5 if I have to buy a new one since I just installed solar heaters on my roof (have not used them yet). when its summer time and I want to use solar heaters, I can crank it up to high speed, and in the winter I can go to low speed without the solar.
    however, I have two really big problems which might prevent me from making this purchase:
    -The new pump has to fit in a space that measures: 24 inches length, 10 inches width. I couldn't find online any specs on the superflo to indicate their dimensions
    -I could not find how you can change from high speed to low speed and if that's something that can easily be done.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    If it's a capacitive start motor it probably has an internal centrifugal switch that disconnects the capacitor after the motor is up to speed. Sounds like that switch may be flakey and not disconnecting, causing overheating. Excellent time for a new 2 speed motor.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Apr 2011
    Houston, TX, USA
    105
    thank you for the late night replies. does anyone know of the dimensions of the Pentair SuperFlo pump?
    also, would 1.5hp be good if today I am using 1hp and I am happy. assume that the solar heaters are on first floor roof and the water has to go up about 9ft.
    thanks guys!
    38,271
    I have a big solar array that is far from the pool on single story and the 1hp works just fine.
    There is a dimensions drawing on they Pentair website I think.
    Also the Superflo pumps come with a speed selection switch on the motor.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Apr 2011
    Houston, TX, USA
    105
    thanks guys. my filter is Pentair FSNP 48. would it be able to handle 1.5hp pump?
    I looked at the manual from Pentair and it did not have the dimensions unfortunately. but it does seem that this Pentair superflo model is one of the smallest in footprint pumps.
    would the installation for a 2 speed pump be very hard?
    38,271
    The dimensions are not in the manual, they are in the MORE tab on the website:
    The electrical installation would be the same as any 1-speed pump because the switch it built-in. The plumbing uses union fittings which are also easier to deal with.
    The filter will be fine with the 1.5HP, but that is just going to cost you more money upfront and more money on electricity to run.
    EDIT: Also note that the switch is on the back of the motor which is not shown in the picture ... thus, I am not sure it will fit ... post up a picture of your equipment pad.
    Apr 2011
    Houston, TX, USA
    105
    dude you are amazing, just like everyone else on this forum.
    Apr 2011
    Houston, TX, USA
    105
    I ordered the new pump (Pentair 340042 Stainless Steel SuperFlo Almond 230-Volt 60-Hertz Single-Phase 2-Speed Pool Pump, 1-Horsepower) and it will arrive in by Saturday morning. Amazon had it for $484 shipped. I am just hoping I don't have a green pool by then. I will put some extra chlorine and run the aquabot tonight.
    38,271
    Hope it fits ... or you can adjust the plumbing to give more room.
    Looks like prices have gone up since the fall ... I managed to find it for ~$400.
    Apr 2011
    Houston, TX, USA
    105
    thanks! I am sure they go up in spring and summer when people need them the most. it was 385 or so in September, you are right
    Apr 2011
    Houston, TX, USA
    105
    thanks guys for the continued support. I have one last quick question. looking at the wiring diagram, the manual is incomplete at best.
    in my old pump, I had only two RED wires coming off my timer and being connected directly to the pump.
    this new SuperFlo pump has 4 different options where the wires can do without any instructions on where to put the hot ones (each of those options is numbered 1, 2, 3, and 4 --- 3 and 4 are on the same connector by the way). Here's their diagram. I have the 2-speed pump with a switch in the back, which I assume is what they call a toggle switch.
    any idea where I can connect my two red wires that produce 230 volts?
    thanks!
    Apr 2011
    Houston, TX, USA
    105
    Quote Originally Posted by michmike
    thanks!
    I think posting this might have caused me to answer my own question. ONE of my red wires should connect to the black wire from the toggle switch. the other RED wire should go to number 1. can someone verify?
    also, I assume when the toggle switch is up it means high speed, and when it is down it means low speed.
    38,271
    Pretty sure everything you realized is correct. There should also be a ground wire running from the timer to the pump.
    Apr 2011
    Houston, TX, USA
    105
    the diagram from the manual does talk about a ground wire, but my previous pump did not have one. I guess I have to go buy one and connect it. thanks for the advice. I assume the ground wire is the green wire as shown on my timer.
    is bonding what is shown on that other picture with my Polaris booster pump? (where you connect a wire to the pump metal structure)
    38,271
    Yes and yes.
    Apr 2011
    Houston, TX, USA
    105
    thank you!
    Jun 2007
    New Jersey
    653
    I assume you know this, but that timer is completely bypassed. Pump is powered permanently regardless of timer or manual switch operation. The dial will go around, though.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
  20. Back To Top    #20
    Apr 2011
    Houston, TX, USA
    105
    Quote Originally Posted by Durk
    yes it was bypassed while I was working on it. I put the wires and the on/off dongles back and it is working as expected now.
