Starting Over
If your water still looks very clear, I would assume you do not need to do the shocking process for now and I would continue to get your cya up to protect your FC better. You probably should shoot closer to 50 ppm cya with your location and sun amount on the pool.
Mike_k said:
harleysilo said:
Ah! Carry on then!
Just to be clear... carry on because of #2 above (CYA). Water doesn't wear out and lose its ability to hold chlorine.
That reminds me of someone who wanted to know at what psi would his truck float on water if he filled the tires with helium!
Sent via Tapatalk...
