Thread: Solar panel install
    Solar panel install
    Hi All. Thanks again for all your past help! Anyway I'm about to start a new pool project, installing 8 4x10 aqua therm panels I picked up on Craigslist. I've been studying g this forum and the web and have a few questions/concerns that hopefully someone can help with.
    I'll be running my piping down a slight hill before it goes up to the roof. I'll have about a 5-6 ft drop from where my pump/pool is, then about. 60 ft run to the house, then up to the roof which is another 25 ft or so. Will I have issues with the panels draining? Will the pressure be enough when the panels aren't bei g used to push water up that hill back into the system? I was p,anni g on putting a t in athte lowest pt for winterizing. My pump is a jandy plus hp 2hp. Any thought is this is enough pump? When we built the pool, I asked the builder to rough out for solar and he did. I attached a pic but do I need another check valve between the pump and the 3 way?
    Thanks for your help.
    25,000 vinyl w Hayward Aqua rite salt located north nj. Waterfall, spillover spa, Polaris 280, I-Aqualink 2.0, Solar fully automated,
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Solar panel install
    Ok, just a few thoughts, you probably want to set up a bypass around the current gas heater, so water flows through it or the solar, but not both. You should be ok with the current pump. I just installed 11 4x12 panels located about 15 feet above ground level, and am getting about 42-48 gpm with my 1.5 hp Jandy Flo Pro 2 speed pump on high, I do have a very restrictive DE filter in there too. The dip should not be an issue other than a place to trap water that might freeze in the winter. Also I would suggest using 2 inch pipe to minimize your flow restriction, your on the borderline of where 1.5 inch would start building excessive backpressure at optimal flow (about 5 gpm per panel) one big concern is overpressurizing solar panels, so you will want to include a bypass around the heat system also in case your 2 HP pump is overkill (might be, but I would not bet on it.)
    Ike
    Ok Thanks. My headers are 1.5" on the panels. Should I run 2" and just size it down right at headers?
    Thanks
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I would think that would work fine, as I said you are on the border line of it making measurable difference, but since the cost difference is so low it is probably best to go ahead and use 2 inch. There is some good information on installation techniques at http://h2otsun.com/ it is of course geared towards their product with some bias in the wording, but never the less lots of good generic information, also the Aqua Therm installation manual is well written and has good information it it. How do you plan to attach the headers, I ended up using the AquaTherm optional aluminum header clamps (well the elm distribution rebranded ones for the 2 inch headers) on my TechnoSolis panels (headers are within .05 inch of the same diameter as the Aquatherms).
    Ike
    The solar panels I bght came with the regular hose clamp brackets, which I was planning on using. Im also planning on replacing the end caps, the hoses and relief valves, just as a precaution. The panels I am using are about 8yrs old, so im going to use new parts. Should I upgrade to the other brackets?
    Thanks
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I used the 2 inch version of these
    http://www.sunsourceproducts.com/catalo ... &part=0215
    and while they may be overkill I liked the option of being able to remove and replace a panel if needed without touching any of the roof penetrations.
