Thread: air pump to force chemicals
    In the aquarium world, I one time used an air pump to pressurize a canister to force a liquid into the tank through an airline. You varied the amount of time the pump ran to change the amount of liquid that got dispensed. Using check valves on both the in and out air lines allowed the canister to stay pressurized.
    Any reason why this wouldn't work to dose chlorine into a pool?
    10k-18k gallon Gunite pool Approximately 4-6 years old
    Blue Haven built w/ all Blue Haven equipment
    Barracuda G2 'pool boy'
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: air pump to force chemicals
    Where do you plan on injecting the chlorine?
    A pressurized container of chlorine doesn't sound exactly safe to me.
    There is this method which doesn't require an external pump or a pressurized system:
    homemade-acid-or-chlorine-injection-system-t4174.html
    Mark
