Thread: Absorb CH from CH Scale?
    Dec 2012
    Manassas Park, VA
    207
    I recently drained my pool and did a light acid wash. However I was unable to get all of the calcium scaling removed. My fill water has low CH (~90), it is my understanding that having low CH in the water can result in leeching CH from the plaster, would it be able to leech CH from the CH scaling?
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Absorb CH from CH Scale?
    Yes, but at a glacial pace. It's not so much just having low CH, but maintaining a negative CSI. Pool Calculator can crunch the numbers for you. I try to keep things about -.5, but its not always possible, especially as the water warms up. progress-on-scale-t38568.html
