Thread: My new 2 speed Century replacement motor
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    405
    I made the plunge and decided to replace my 1hp Hayward Superpump motor (single speed) with this AO Smith/Century motor. So far looks like a good move, as this motor seems to be made so much better than the motor that came with the pump (another AO Smith, but like a lot of things I suspect a replacement motor is in a different class than an 'OEM' motor attached to pumps being sold).
    Interesting is the lack of paint on the ends of the motor, which differs from the pictures you see online. I called the manufacturer and found that the metal is aluminum, so it shouldn't rust. Apparently they had problems with paint staying on the aluminum and decided to avoid it altogether.
    Also interesting is that the motor is 3/4 HP full rated but according to the sticker its actually 1.13 HP.
    This motor is an inch or so fatter than the original motor, so I had to trim the based that the motor sits on.
    16x32 Concrete IG 24k Gallons
    Equipment: Carvin 525sf Cartridge Filter, Jandy Gas Heater, Vortex Solar Panels w/solar valve, 1hp Hayward Pump with 3/4 HP AO Smith 2 Speed Replacement Motor, Aquarite Saltwater Cell, Polaris 280 Dolphin Active 20 Robot
    Automation: Hayward Prologic Controller
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: My new 2 speed Century replacement motor
    The sticker is showing the Total HP which is different than the label HP. So the total HP = Label HP (0.75) * Service Factor (1.5) = 1.125 which is rounded to 1.13. The "True" HP is the total HP and that is what should be used when sizing a motor. As long as that is larger than the previous motor's THP, then it should work fine.
    Mark
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Which model motor did you purchase?
    mas985's Avatar
    Pleasanton, CA
    11,742
    Yea, that looks to be the wrong frame for a Superpump.
    Mark
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    405
    Quote Originally Posted by linen
    B973
    The service factor on the old motor was 1.1. So 1.1*1 = 1.1. Pretty much an exact match to this new one. Except this one is rated at 11.2amps for the high speed and 5amps low (the old motor was 15amps). So a little bit of amperage savings there.
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    405
    Quote Originally Posted by mas985
    It was easy to trim the plastic footing with my jigsaw. Trimmed all of 3/8". Sits fine now. Mark, any chance you could chime in on the thread I started (questions-for-mark-t58906.html) that had a few questions for you, even though its sort of irrelevent now since I bought the new motor. I was most interested in how you can "get away" with using a 1/2HP motor considering your pool size, 2nd story solar panel, etc....
