Thread: Manual spa cleaning options? Is pressure or suction better?
    Sep 2012
    Foster City, CA
    43
    Hello,
    I have an early model Polaris 3900 Sport that works inconsistently, gets stuck often, and only cleans the pool. I generally brush everything towards the main drain and hope the pump/filter and 3900 eventually pick everything up.
    Saw a few posts where folks are draining the spa, then brushing and shopvac cleaning, but I'm looking for pole attached solutions (under $100?) that will allow me to vacuum finger sized leaves, bugs, sand, dirt, and dust from the attached spa, and spot vac the pool as needed.
    I've read a bit about garden hose leaf baggers, but wondering about their effectiveness on smaller debris. I'm curious about hose attached skimmer/suction powered options. Also wondering if there's any way to take advantage of either higher pump speeds, or attaching something to the dedicated return line of the booster. Is the Polaris UWF truly "universal" or just for Polaris Automatic cleaners?
    19k gal IG gunite w/ spa, Sta-Rite IntelliPro VS, Sta-Rite System:3, Polaris 3900 Sport w/booster pump, Heliocol, EasyTouch4
    Re: Manual spa cleaning options? Is pressure or suction bett
    I use this thing. It works pretty good for a spa. I have two gripes; 1 - it doesnt hold a lot of debris, figure a handful of average sized leaves 2 - the on/off design of the thing is stupid. However, for the money it does a great job and even if it only lasts a couple of seasons its stil a good solution.
    http://www.amazon.com/Water-Tech-BRO...ywords=spa+vac
    Walnut Creek, CA. 18k gallon Pebble Sheen + 1.5k gallon IG spa, 1.5hp whisperflo main pump, Pentair clean and clear 420, Intellichlor IC20, Polaris 360 w/booster,Jandy lite 2 natural gas, plus solar with Heliomatic 5000 controller and 3/4 hp booster
    Apr 2009
    Northern Virgina
    55
    I've used a variety of spa cleaners, from hand pump types to battery-powered but I am currently using the Rainbow Spa Mini Vac
    http://www.spa-daddy.com/Rainbow-Spa-Mi ... 4Aod9C0Aig
    which I operate from a garden hose. I found that with the rechargeable cleaners, the battery or motor eventually dies and it was easier to just hook up the hose to the mini vac rather than get the battery-powered cleaner out of the garage, clean it, and then put it back again. I also like the fact that you attach it to the end of a pole so I can get to spots in the deep end of the pool if needed.
    22k gallon IG Anthony free-form pool and spa with PebbleSheen finish, Pentair WFDS-8 WhisperFlo Full Rated Dual-Speed 2HP pool pump, Sta-Rite S8D110 System 3 Grid D.E. 53 sq. ft. pool filter, Raypak R406A 399K BTU cupro-nickel propane heater, Polaris 280 pool cleaner with 3/4 HP PB4-60 booster pump, Goldline Aqua Plus controller and SWG, Inter-Fab G-Force pool slide.
    Sep 2012
    Foster City, CA
    43
    Thanks for the feedback. Avoiding batteries & motors sounds great.
    The Rainbow looks like a winner. I like the option of the adding a skimmer hose in the future. In for 1!
