Thread: Second season, pH still going up
    So Im in my second season. My pool should be cured. But Im still using about 2 gallons of acid a month. This is a lot better than last year when I was using 16-32 ounces/day
    We dont have any water features, but we do have a spa spill over that I barely have running, just enough to keep water flowing into/out of the spa. It doesnt really splash, but just keeps the tiles on the spillover wet.
    There is a small air leak on the spa returns so a few bubbles come through
    Some of the returns disturb the surface water, but no bubbles or anything, just surface swelling and swirling
    Are these enough to cause pH to keep rising? Could it be anything else?
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    38,301
    Re: Second season, pH still going up
    Everything you mentioned will contribute some, but the bigger question is: What is your TA? If that is high, then that will drive the pH up faster.
    Then the question is what is the pH and TA of the water you use to top off the pool?
    My TA is 60, TA of fill water is 170, pH 8.3
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Yeah, that'll do it.
    I learned from experience that every inch of water I add to my pool requires about a cup of acid. Now I just dump it in while I'm filling and fine tune things if necessary the next day.
    38,301
    Honestly I am surprised your pool is only at 60ppm with such high TA and pH fill water ...
    I add a lot of acid..
    Some off topic rambling has been moved here.
