Thread: Pump selection
    Pump selection
    Good day all.
    I have a 24' AGP.
    My old Jacuzzi Pump (7LA-S1) finally packed it in after I have no idea how many years so I'm looking for a replacement.
    The old Jcuzzi was 3/4 and I imagine not the most effiecient pump design.
    I was leaning toward a 1HP Hayward Matrix just to get a bit more water moving but as the old pump had no problem keeping the pool clear I thought well maybe 1HP might be too much.
    So I began debating a 2 Speed 1.5HP Matrix. I am assuming at half speed, half the flow and HP which would might match what I had and I would have the extra for heavy use or cleaning.
    Is there such thing as "Too much" pump (and I don't mean reference a 3 phase 5HP pump ) ie would the NEW 1HP Matrix but substainly more pump than mu old Jacuzzi?
    Other info, I have a heater and Sand Filter. SandFilter is also an old Jacuzzi
    Thanks guys.
    24' Round AGP, 14,000 gals, 125000BTU heater, 18" Jacuzzi Sand Filter, 3/4 Jacuzzi Pump
    38,521
    Re: Pump selection
    Welcome to TFP!!!
    The only reason you need a large pump is if you have high flow rate requirements ... spa, waterfall, etc.
    A bigger pump will cost more initially and use more electricity.
    I would suggest looking for a small 3/4-1HP 2-speed which will be run on low most of the time. On high, they are the same as a single speed. On low they move 1/2 the water for 1/4 the electricity, so even doubling the runtime will save 50% of the power cost.
    Please add your pool details and location as described HERE as it will help us help you.
    Re: Pump selection
    Thanks JB..
    I will plan on the 1HP 2Speed Hayward Matrix then (unless you have another suggestion on the brand )
    38,521
    Re: Pump selection
    I think that should do you pretty well
