Thread: Stenner Pump Mounting Location Options...
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    So on my new pool I am looking to install a Stenner pump. But I am torn how to mount it.
    I live in Arizona, and our houses are generally all stucco. Under the stucco is foam, followed by 1/2" plywood. The thing I am worried about is installing it against the house and is possiability leaking at some point (and chlorine running along the stucco and wrecking it.
    Any ideas of other ways to mount it? Flat Steel Stock? Drive a pressure treated pole into the ground next to the barrel maybe?
    IG, 18K gallons, 100' Perimeter, 565 SF surface area, 980sf interior area, Max Length -36', Max Width - 16', Pentair 520 Clean and Clear Cartridge Filter, Stenner Chemical Injection System (Chlorine, Acid Coming Soon) , Pebble Tech - Blue Granite, Pentair variable speed filter pump, Zodiac MX8 Cleaner, Multi-Colored LED Lighting, Travertine coping & Decking, Boulder Water Fall....
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Re: Stenner Pump Mounting Location Options...
    I agree - I wouldn't want to mount the thing where a split hose or a leaking fitting will create more problems.
    I'd look for one of those T-shaped metal fence posts for wire fences just because they'd be easiest to drive into the ground with a sledge hammer. I'm not fond of shovels or post hole diggers myself. Just take care selecting the location so that you don't drive it right through your buried plumbing or electrical! Because then you'd be back to the shovel...
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Maybe a board attached to the barrel with a couple of straps? I hate the digging too, even with a tractor mounted auger around here you have to pry out rocks occasionally to get a hole in the ground. Last time the auger tossed a softball sized rock 7' up into a pear tree.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    I appreciate the advice guys!
