Results 1 to 16 of 16
Thread: BBB method convert....Now What?
    Apr 2013
    NW Ohio
    83
    I opened the pool about 2 weeks ago. Grabbed 2 cases of 12.5% chlorine $2.75/gal...
    Also picked up a gallon of 31% muratic acid.
    For now I will manually dose the Chlorine as needed.
    I also just ordered the tf-100 test kit. Will report numbers back when the come.
    In past:
    I aimed for Chlorine ~ 2ppm using basic test strips....Typically would use 3" tabs in chlorinator
    I would just dose a 60% algacide weekly just because and never had an algae issue....
    I would also shock with a bag or 2 of shock weekly as well during summer....
    I would adjust pH with dry powders. What should I expect with pH now since no Tabs?
    So now:
    do I still need to shock? And what do I use? And when, weekly or based on the chlorine tests?
    do I still need algacide? And if so i read only polyquate 60% Recomended brand? weekly or just if I see some cloudy?
    Clarifier?
    Anything else?
    18x37 Vinyl Grecian (24k gals) 8' Inter fab(la mesa) Diving board w/ waterfall & Led, Pentair Laminars & Intellibrite 5g
    Star Rite System 3 Cartridge Filter, IntelliPro 3HP Variable Spd Pump, Max E Therm 400k BTU,
    Pentair Easy Touch 8 & actuators,...Now looking to BBB
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: BBB method convert....Now What?
    Clarifier?
    Once you get your kit post numbers here and we can advise. On BBB you won't normally have to shock (verb not a noun). If you do you just need chlorine and patience. Most members don't need algaecide or clarifiers but in rare instances they can help. Use pool calculator to figure how much chlorine to add, but without knowing what your CYA level is it's going to be hard to say.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by blownby
    In past:
    So now:
    Clarifier?
    Anything else?
    If you maintain minimum FC for your CYA level all season long, you may never need to perform the shock process. And if you do, it's based on water quality and test results, not just some vague idea that it's about due.
    You won't need algaecide, either. Some people put some in before they close the pool in the winter. But if you maintain FC for your CYA level, you won't need it.
    You shouldn't need clarifier if you maintain the proper FC for your CYA level, either.
    Do you see a pattern here?
    For the last couple years, my pool has been fed nothing but 12.5% sodium hypochlorite, 31% Muriatic acid, and Trichlor pucks when I'm out of town. That's it. And my pool is clear enough to toss a dime in the deep end and call heads or tails from the deck all year long.
    All you need is a little bit of knowledge and hard facts from your own, proper test kit.
    Apr 2013
    NW Ohio
    83
    Ok,
    Thanks...last look based on quick dip strips CYA was like 30 or a tad lower.
    Hopefully new test kit is here early next week for solid numbers!
    Also I have a vinyl liner. At what point does chlorine levels become harsh to it?
    I still have a little more studying up in the pool school, but have a basic understanding, just need to grasp the ratio stuff and then how to balance numbers accordingly.
    Apr 2013
    NW Ohio
    83
    How do you figure what an ideal CYA level is?
    The pool will have full sun on it pretty much from 10am till 4pm and then from 4-dark about half pool has sun....
    Avg summer water temp is 78* during summer. need anything else?
    Richard320's Avatar
    Jan 2010
    19,037
    For the shock process, 30 is pretty good. Once the water is sparkling, up it to about 50. But if it works out that one bottle will take you to 45 or so, don't sweat it. pool-school/recommended_levels
    38,371
    Start with 30ppm, if you feel like you are loosing too much to the sun, raise it up some, but we do not recommend more than 50ppm for non-SWG pools as other problems can develop, like the pain of following the shock process if required.
    Apr 2013
    NW Ohio
    83
    Ok, I will leave CYA as is for now.
    Any idea what an avg amount of say 12.5% chlorine I should use per month (24k gal & lot of sun & avg use)?
    Is 4gal little or a lot or about right? I know will depend on a lot, but any ballpark avg.
    Ok, read thru the and trying to grasp FC, CC TC....
    It seems TC is the typical every day test via OTO yellow drops color
    and FC via test strips...
    So if FC is basically what sanitizes why the test for TC typically via OTO test?? Ease?
    FC should be 3-7,
    TC should be ??
    CC should be ??
    38,371
    It is normal to lose 2-3ppm of FC per day. Multiple that amount by 30 and that is your usage per month ... use the poolcalculator.com to figure out how much bleach that is.
    In a clean/clear pool, the CC is usually 0-0.5ppm, so using the OTO test is basically giving you the FC.
    If CC > 0.5ppm, then something is going on and you need the shock process.
    Apr 2013
    NW Ohio
    83
    Wowzers....
    So for a 24K gallon pool, I basically need to raise the pool FC from 0-75(avg) 2.5x30 to calculate....
    It says at 12.5% I need 1792oz....or just ~14gals a month?!
    So at say $3 a gal I am at ~$42 a month for chlorine. Sound about right? That a lot of lugging!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yep, that sounds about right for an approximation. That is why (partially) some of us have gone to using an swg (the lugging issue not the cost)
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Which is why some people use a swg or other method to provide the chlorine. BBB is mostly about knowing what's happening with your pool.
    Dan D
    Isaac-1's Avatar
    SW Louisiana
    6,711
    In general those dip test CYA tests are not that accurate, you really need a CYA liquid turbidity test , and even then it is very important to run the test in the right lighting condition (outdoors with the sun to your back), the sticks do give you a ballpark figure, but it is a VERY BIG ballpark
    Apr 2013
    NW Ohio
    83
    I have the TF-100 test kit coming!
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I usually pour the CYA solution back and forth 3-4 times to make sure I'm reading it right.
    Dan D
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Quote Originally Posted by msgtdan
    I do as well, and then pass it off to the kids or wife to get a second opinion.....
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
