Thread: CYA
    May 2013
    Norman, Ok
    35
    CYA
    I've drained and refilled and have the CYA at what I think (kit shows up today or tomorrow) is a workable level.
    Q. Throughout the summer, will CYA levels be affected by evaporation? That question has been driving me nuts for a week
    18 x 30 IG vinyl "sports pool" 16k
    Hayward pump & sand filter. Polaris cleaner (older model) & booster pump.
    K-2006 test kit
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: CYA
    Yes, as you refill lost water your CYA will go down.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    May 2013
    Norman, Ok
    35
    Re: CYA
    Thanks! I just didn't know chemically speaking if CYA would be a part of the evaporation process or if it separated from the water evaporating and remained in the pool! Thanks again.
    K-2006 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: CYA
    Quote Originally Posted by RowdyC
    Not really. CYA doesn't evaporate. For illustration, let's say your average pool depth is 50 inches (makes easy math). If you let the level drop 2" before refilling, that's 4%. If CYA was at 50, it's now at 52. You probably won't see that change on the tester view tube. And when you refill it to bring it back up to 50" deep, CYA will be back at 50.
    The only way you lose CYA is by splashout, what sticks to people when they get out of the pool, and what you lose when backwashing. Remember, you're measuring parts per million. That's pretty small. 50 ppm is only .005%
    thehowheels's Avatar
    Apr 2013
    SoCal
    120
    Re: CYA
    CYA does not evaporate. You can reduce your CYA by draining / backwashinig, or through splash-out. There are some reports of pool owners experiencing unexpected CYA loss after closing and re-opening, but it is definitely not typical.
    Matt
    9k gallon, plaster, IG. Raised spa w/ spillover into pool. AO Smith Century Centurion / Purex Triton WisperFlo 0.5 HP, Hayward 1.5 HP (spa), Polaris 1-516-01 1.5 HP (blower). Hayward DE3620 36 ft2 72 GPM DE Filter, Polaris 145 cleaner. Pool built ~1980.
    Trouble-free, BBB since: April 25, 2013
    May 2013
    Norman, Ok
    35
    Re: CYA
    Thank you both! I'm trying to convert a neglected "pool store" pool into a BBB pool. So as I'm trying to be patient, I'm thinking about things such as this CYA thing. Thank you. And BTW, we just bought the house and pool in November, so I'm NOT the neglectful party.
    K-2006 test kit
