Results 1 to 7 of 7
Thread: Speakers
    May 2013
    Norman, Ok
    35
    Speakers
    I'm not really a speaker/stereo guy, but I want to have some speakers outside, around the pool. I have some Bose surround sound speakers not being used (with the new house when purchased), will they sound okay hooked to a stereo system? Just not sure how SS speakers work vs. regular stereo speakers music wise.
    Thanks
    18 x 30 IG vinyl "sports pool" 16k
    Hayward pump & sand filter. Polaris cleaner (older model) & booster pump.
    K-2006 test kit
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Speakers
    What type of stereo receiver do you have?
    Would the speaker be subject to rain/sun in your proposed location?
    Surround sound also come with a sub woffer, did they leave that too?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    May 2013
    Norman, Ok
    35
    Re: Speakers
    I don't know what type they are other than Bose. They are mounted from the ceiling in the "back" of the viewing area. They will be mounted under the covered patio, protected from sun and 97% of rain...some blowing rain may hit them from time to time.
    The stereo unit would just be some old Sony or whatever the kids have left in the garage thru the years. I might consider buying a new one that was compatible with iPhone/auxiliary input.
    K-2006 test kit
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Speakers
    They make outdoor speakers, designed to handle the humidity and rain. I can't really suggest you using indoor speakers outside.
    I have these mounted outside... http://www.jamo.com/speaker-types/outdoor/?sku=I-O8A2
    My first set lasted 4.5 years and then the speakers blew, they replaced them under warranty. Mine are mounted under my eves, but get sun and blowing rain.
    The best forum on the web for stereo's is http://www.avsforum.com/f/159/outdoor-theaters
    Those guys know their stuff.
    IF you start researching new stereo receivers prepare to have your mind BLOWN. Most require them to be and integrated part of your entertainment system, and require them to be hooked up to a TV to set the 1 million possible settings. Sure you can get something that is much simpler.
    My fairly new stereo receiver runs my living room setup AND my outdoor set of speakers. I can be watching TV inside and playing different music outside.
    If you decide to try and integrate your itunes, you can hook up your computer to your stereo and then use your iphone to control everything.....talk about sweet.....
    18'x43' Sport Pool
    Feb 2013
    San Antonio, TX
    13
    Re: Speakers
    For what it's worth, I replaced some old outdoor speakers with these:
    http://shop.emotiva.com/collections/spe ... ucts/uom62
    I couldn't be happier; I hooked them up to an old Yamaha receiver I had laying around. They sound awesome for 200 bucks.
    I also wouldn't recommend putting indoor speakers outside. They'll wear out a lot faster than speakers made for outdoors.
    18k(ish) gallon IG plaster/painted "Lazy L" shaped pool most likely built in 1975.
    30" 500lb Hayward sand filter.
    1hp Hayward super2 pump.
    Polaris 9300 Sport Robotic Cleaner.
    TF-100 test kit with speedstir.
    May 2013
    Norman, Ok
    35
    Re: Speakers
    Thanks for the feedback and especially the links. Now I'm just not what to do with these speakers in my ceiling. Think there's a market for them on CL?
    K-2006 test kit
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Speakers
    LOL there is a market for EVERYTHING on CL. Seriously yes somebody will want them....
    18'x43' Sport Pool
