Results 1 to 7 of 7
Thread: Light Niche Prior to Collar Pour?
    Feb 2012
    Maryland
    400
    Should the light niche be installed before pouring the collar? And should the concrete come up around the bottom of the niche? My niche bottom is only 8 inches off the ground, so if I pour the suggested 10-12 inches it will be 2-4 into the niche.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    30,419
    Re: Light Niche Prior to Collar Pour?
    Not much info here to respond to. Are you building this pool? Do you have a PB?
    If the bottom of the niche is below the level the concrete will reach, the niche needs to be in place before you pour concrete.
    Feb 2012
    Maryland
    400
    My info is in my sig Its a DIY 18x36
    The bottom of the niche will be below the level of the concrete, but I wasnt sure if it was normal setting the niche in concrete like that or if I should build a boxed area behind the niche to have the concrete not right up against it.
    There is no problem having the niche in place as long as you either leave the area where the wiring conduit attaches clear, or also have the wiring conduit in place in advance as well.
    Nov 2011
    Moberly,MO
    1,010
    I would recommend not having the niche bedded in the bond beam concrete
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Feb 2012
    Maryland
    400
    Quote Originally Posted by swimcmp
    I think ill put the niche in, and build some forms around it on the outside to keep the concrete several inches from the niche.
