Thread: Cleaning Concrete Deck
    Mar 2013
    CT
    349
    We just bought a house with a 16 x 30 in ground pool. I wanted to clean the concrete around the pool since it's very dirty and could use some brightening up.
    Any suggestions on what products to use?
    Can I have it power washed???
    Thanks!
    Dan
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Re: Cleaning Concrete Deck
    I've had the best luck with power-washing. I've used it with the soap-injector, but it didn't seem to make a big difference. I would warn not to get too aggressive with the wand/pressure. Most all concrete has some type of aggregate (pebbles) and I've seen where the high-water pressure blasts the cement and leaves the aggregate exposed making a rougher surface. The rougher surface makes a good surface for trapping dirt and algae making it more difficult to clean next time. I haven't tried it on my cool deck yet but will certainly start light. This is what I recommend for patio, deck and drive-way cleaning ~
    http://www.lowes.com/pd_106124-348-6...7C1&facetInfo=
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
