Thread: 1700rpm for skimmer and vacuum on VS3050 normal?
    I just had a VS3050 installed and am trying to find out how low I can run it at with my skimmer and dedicated vacuum lines open, and still get good vacuuming. Right now it looks like the floor is about 1700rpm. At 1500rpm I have to shut off the skimmer line to get good vacuuming. Does that sound about right? The pump sounds about like a diaphragm aquarium pump at that speed, just a low hum. I have 2" plumbing and just the skimmer and vacuum lines (main drain goes into skimmer). Filter is a Mytilus 150sq ft cartridge, returns are four in the pool and four jets in the attached spa. Pool is 15k gallon in-ground gunite with attached spa. I'd be very happy if I could reduce my electricity usage by 75%. Old pump was a 2hp Pentair Challenger (way oversized).
    15k IG gunite w/attached spa, Pentair VS-3050 pump, PacFab Mytilus 150 cartridge filter, The PoolCleaner 2X suction cleaner, Liquidator still in box in garage
    1700 rpm while vacuuming sounds plausible, but you presumably aren't vacuuming all the time and so could run at a lower speed when you aren't vacuuming.
