Thread: Pool Pilot/Salt Chlorinator Maintenance Questions
    Jacksonville, FL
    After a year of pool ownership, I feel like I am still a newbie. I have some questions about ongoing maintenance (not adressing problems, regular day-to-day) that I have gotten very mixed responses from the pool store about...
    I was told that there is a need to shock a salt pool on a regular basis and I have been told not to shock a salt pool, the Pool Pilot will take care of it. Should you shock a salt pool with chlorine chemical packs (not containing calcium, I have learned)? If not, and the Pool Pilot will take care of it, does this mean automatically or do I need to manually 24 hour boost on a regular basis? If I do need to boost or shock, how frequently?
    I'm sure I have contributed greatly to my current algae problem and am trying to make sure, once it is gone, it doesn't return. Since TFP has Poolsean, I was hoping he could set me straight and help me save myself from myself
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    You don't need to shock the pool unless something goes wrong. Shocking is normally done to kill algae or to eliminate combined chlorine (CC). SWGs are normally very good about eliminating CC on their own, though getting significant CC in a pool exposed to sunlight is rare anyway.
    If you don't already have a test kit that can measure CC you should get one. The FAS-DPD chlorine test is the standard everyone here goes by. There is a great test kit sold through an associated site, see the TF Test Kit section on this forum.
    Pool stores tend to recommend shocking the pool reguarly because they figure people are clueless and have been getting their chemistry wrong. Shocking the pool is one way of getting back to a known state after verious problems that the clueless might not have even noticed. If you test your levels reguarly, which you really ought to be doing, you will know when there is a problem and only need to shock then. If you take good care of your pool the only time you will need to shock is on opening in the spring.
    DaveNJ's Avatar
    Toms River, NJ
    JasonLion is right on the money. I've had a SWCG for about 2 1/2 years. The only time I shock (bleach) is opening in spring. I have a test kit and monitor my water regularly. I don't cover my pool in winter, so its pretty bad by the time I open it. Three days of bleach and running the pump, balancing out the water and its clear.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    Ft Lauderdale, Florida
    Who needs me when you have Dave and Jason!?
    Sean Assam -
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps
    AutoPilot Salt Chlorine Generators
