Thread: Replacing equipment - should it be changed?
    Aug 2011
    Northville, Mi
    312
    This is actually for a buddy of mine, who just bought a house that didn't winterize the 12K inground fiberglass pool. He's been told the filter, pump, and heater all need to be replaced. In honesty, we had a pretty mild winter here in SE Michigan, although it did get pretty cold for a good stretch. First question is does that sound like what to expect if you don't winterize - all that equipment to be broke?
    The second question is, since he's got to replace it, should he make any changes? It's all Hayward equipment - a 1HP super pump, an s244t sand filter and an H150 heater. No idea how old the original equipment was either, but, in a green field, would you replace any of this stuff with different sizes, etc or a different manufacturer?
    15,400 gal, 16x32 vinyl rectangle (sport dig), Intelliflo VS, 240 sqft cartridge filter, Intellichlor IC40, Mastertemp 250, Dolphin supreme M4 cleaning, Pentair EasyTouch4, Tested regularly and accurately with supplies from tftestkits
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Replacing equipment - should it be changed?
    The best way to tell would be to fill everything up and try to turn it on. If its all leaking, it needs replacing.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by doncaruana
    If replacing the pump is deemed necessary, I would get a 2-speed pump instead of a single-speed. That will save on the electric bill. Two-speed pumps are becoming much more popular and, as a result of increased production, they do not cost that much more than single-speeds.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    I suppose if someone eyeballed the equipment and could see where the pump housing and the filter had cracked it would be possible to condemn it right away.
    I'd try starting it up and see what happens. If it's already trashed, he's got to replace it anyway and no more harm will be done. If it's not trashed, he's saved $$$ and has gained valuable insight into the pool service's business practices.
    May 2011
    Orange County, CA
    696
    Quote Originally Posted by Richard320
    My thoughts exactly! Check it out, at least for a short test. At this stage, it couldn't hurt.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
