Thread: When is it time for a new cartridge filter? High PSI
    Jan 2011
    Houston, TX
    56
    Hello,
    I have gotten into a cycle where my pump pressure gets up around 30-32 psi and then it is time to clean the cartridge filter. I hose it down and then it goes down to 20 psi. Then 2 weeks later it is back to 30-35!
    My pool is crystal clear, pump runs about 10 hours a day, and I have shocked it to ensure there is no FC. Since the pressure keeps going up, is this an indication a new filter is required?
    We have been in the house for 2.5 years and I am not sure of the maintenance of the filter before that point.
    When you replace a filter, is it strictly on a yearly, 5 yearly, etc schedule... or is it time to replace it when you get high PSI ratings that wont go down with a clear pool?
    CYA is around 50, TA, PH at normal levels.
    Thanks, Aaron
    15'x30' 10K gal, in-ground, cartridge filter, waterfall, spa, The Pool Cleaner, Purex Triton 250 heater, pool built ~1999.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: When is it time for a new cartridge filter? High PSI
    You shocked it to make sure there is no FC? You mean CC, yes?
    Assuming your normal levels are in line with our recommendations, I would say your guess is a good one. How many sf is the filter?
    Cartridge Filters can last 4, 5, 6 years depending on their use (were they used to clear a swamp, etc.) and how they were maintained (cleaning routine - see Pool School article on cleaning cartridges). If they weren't used for a swamp and were cleaned and stored properly yes it extends their life. I would say your's is probably done.
    Jan 2011
    Houston, TX
    56
    Yes - sorry meant to say no CC. Whoops!
    My other levels are ph = 7.5, TA = 110, CH = 220.
    I'm in Houston, so I don't close the pool for the winter - so the cartridge filter stays in year round.
    Thanks for the quick reply - so generally a high PSI that does not stay down after filter cleaning (assuming pool levels are good) is the way to tell if you need a new filter?
    11,969
    Yes.
    Jan 2011
    Houston, TX
    56
    I just wanted to update you, I soaked the filters in muriatic acid for 45 min and the psi went down from 35 to 16! Will keep an eye on it and let you know.
