Thread: Timer
    Mar 2013
    CT
    351
    Timer
    My wife and I just closed on our new house yesterday and so I had some time to inspect the pool, pump, filter in more detail.
    The pump is plugged into an electrical box that basically has just an on/off switch on it. There is no timer.
    Can anyone recommend a quality timer or are they all pretty much the same? I don't need anything fancy or anything with different speeds on it. Just a basic above ground pump timer that will handle the pump load.
    This is an in ground pool (16 x 32) with a cartridge filter.
    Thanks!!
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Mar 2013
    CT
    351
    Re: Timer
    After doing some research, I came across these:
    Would one of these be ok? And - What is the difference between the two:
    Intermatic T101P
    http://www.amazon.com/Intermatic-T10.../dp/B0039QEJ5E
    Intermatic T101R
    http://www.amazon.com/Intermatic-T10.../dp/B000BVZB3E
    Thanks!!!
    Jun 2011
    Long Beach, CA
    2,790
    Re: Timer
    The T101P has a plastic housing, the T101R has a steel housing and they are used if you have 120V input. If you have a 220V system you need to get the T104R timer. I recommend to get the steel housing.
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    Re: Timer
    I have the Intermatic Model ST01 series - love it. Its 6 yrs old, so I am sure this model has been replaced by another. Multiple programs, easy to use.
    18,000 gal, 18x32 IGP, vinyl liner, 3 to 5.5ft depth. One inlet/skimmer (Aqua Genie), one main drain. Hayward Pro Series Sand Filter w/filtration rate of 20 GPM/FT, Two-Speed Pentair Whisperflo 1 HP pump, Natural Gas Hayward H200 pool heater, Aquabot T2 (200 Series) Robotic Pool Cleaner (my best friend), Automatic Electric Pool Cover (2nd best friend).
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Re: Timer
    I depends on where it will be located. Intermatic makes a good mechanical switch. If your needs are 120v then the 101 line would do. 220v is the 104 line. If it's located outdoors then it needs to be NEMA 3R. That will have the gasket around the door. I would get the metal one. I have seen the plastic doors fail over time. Another thing is the clock motor can be replaced in the future if it fails without getting a new unit.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
