Results 1 to 10 of 10
Thread: Total frustration with my filter
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    So every year I battle with my start up of my pool and this year shall be no different I'm sure. I have a freeform 14x33 pool. Tough to calculate gallons on the pool calculator as free form is not an option. Based on rectangular it is 18k gallons but I know it is not.
    I have a pentair 4 speed intelliflo pump with a 420 cart filter. Pump,works great, cart filter is the bain of my existence.
    I know many love theirs and believe me I have tried. I have spent countless hours trying to get this thing to work great and I have failed.....miserably. What does it come down to.......sheer laziness....hating to need to constantly take apart a cart filter housing to clean 4 huge carts every season. I have algae issues every spring, I BBB the daylights out of the pool but fight a filter battle every year. The last 2 seasons I have resorted to purchasing new carts for every season and it helps but is expensive and seems ridiculous.
    I have tried cleaning the carts, I have tried rotating the carts, I have tried washing them daily but I still have not won the battle.
    I am considering a new filtration method....maybe sand? What would be best for my lazy bones that is tired of fighting a no winning battle? Any thoughts are much appreciated!
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Total frustration with my filter
    Whoozer - did you see that? It's a pig flying! Okay, after two full seasons of working with just about every kinda filter....this former Cartridge Fanatic is singing a new tune. I never had to clear my personal pool from "swamp". Ever. Even when it was I considered the bain of my existence. LOL So back in the day on TFP I swore by Cartridge as being "the best".
    Fast forward to now, when I'm recommending my clients replace their occasionally aged/inherited and lacking, and/or malfunctioning equipment, I push them towards sand, or if money is no object - DE. As much of a pain as DE can be, Its awesome. Sand and DE filters, most good set ups will have a recirculate setting on the multiport and a vac to waste setting which carts usually don't. Not to mention having to dismantle to clean. So that's the advantage of the sand and DE, the backwashing... I cleared a green, ammonia ridden pool with a DE filter in less than 7 days without having to clean the grids once. Backwash, yes, but not breakdown and clean. Of course the filter was a great one and oversized so that helped...
    mccarthy before by poolmom11, on Flickr
    mccarthy after by poolmom11, on Flickr
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Wow, I have looked at the DE filters.....ouch on the price. Since,I know nothing of sand filters what is recommended? Should I stick with Pentair as that is my pump? Also with sand what size? Should I over size? Thanks for the info!
    11,969
    yes bigger is always better on the filter. Dave should chime in - I remember he posted a pic of his filter once the thing is huge. lol
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Also, side mount or top mount?
    11,969
    Top. Make sure you plumb in unions for easy removal to check the sand
    Mar 2013
    Central Iowa
    171
    Quote Originally Posted by frustratedpoolmom
    WOW!!! That is amazing!!!!!
    2014 Used 33'x54" Wilbar Morada,deep end approx 28,800 gal.
    Hayward S180T1580S pump/filter combo,
    Pentair Aqualuminator light/return, Aquabot S2-50
    TF-100 kit, Initial fill with pond water
    South Central Iowa
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    What are the advantages of the top mount as it is currently plumbed for a side mount for the filter cartridge. Just curious. I can replumb but would prefer it to be easiest.
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Any thoughts on what size I need? Can't afford DE looking for a sand.
    38,548
    A general size recommendation for you would be a 24" sand filter ... but like has been said there is nothing wrong with going a little bigger.
    In reality, your cartridge should have been plenty big, we would have recommended at least 260 sqft. I think your bigger problem is improperly closing the pool such that you end up with a swamp to clear. If the FC was maintained correctly, I would not be surprised if you only had to clean that 420 sqft filter once a year. But, once you have an algae bloom, the cartridges are certainly a lot of work.
