Thread: Whyy is ph Neon pink?
    Jul 2012
    CA
    240
    Ph is bright almost neon pink
    & Cl is a little low @ 1.3
    ta@17
    salt@4700ppm
    cya low @ 20
    Taylor kit
    pool is a little green.
    Does it hurt to shock if ph is high, pink means 8+ right??? if i add acid can i shock in 30 min or do i have to wait coulpe days?
    Can i use liquid chlorine in salt pool?
    Thanks guys
    25k I/G ecostar ccplus Polaris plaster
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Whyy is ph Neon pink?
    Your pH is high. You can add some acid then shock, and you can use liquid chlorine in a salt pool.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Quote Originally Posted by marty
    ta@17
    salt@4700ppm
    cya low @ 20
    Taylor kit
    Thanks guys
    Is that TA a typo? Make sure you enter the correct value when you plug the numbers into pool calculator to find out how much acid to use. And you might need to add it more than once, because if you enter 8.2 and it's really 8.5.....
    Let the water circulate for half an hour or so after adding acid. It also helps to brush a little to really mix things up. Once pH is close, then you can start the shock process.
    Jul 2012
    CA
    240
    Ok sounds good! its a 12k pool is 4700 ppm ok or should i drain some? thanks guys. no thats not a typo 107ppm
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    So the TA in your first post as a typo at 17, not 107. 4700 ppm salt is too gigs for most SWGs.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Jun 2011
    Long Beach, CA
    2,781
    Their range is 3000-4500 with ideal at 3400. I would verify that your salt level is at 4700 and drain enough to get back to 3500.
