Thread: Bad calcium problem; leaching out of stone?
    Mar 2012
    Ft. Worth, TX
    1
    I am having a huge problem with scaling all underneath the waterfall area. This never happened the first 7 years of the pool, but has gotten progressively worse over the last year. I can clean it all off only to have it return in a few days time. I take my water in to be checked and stay on top of anything that's needed. They say it's leaching out of the stone and sealed it for me last fall. Didn't help. The photo is from last year. Of course over the winter it has gotten quite thick. (It's pretty hard to clean this area from outside the pool.) Is there anything we can do? This is ugly and very time consuming. Thanks in advance for any suggestions!
    Will
    15x48 Intex Metal Frame Above Ground Pool
    Intex 2650 GPH Saltwater System & Sand Filter Pump Set
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Bad calcium problem; leaching out of stone?
    It's called effervescence and it's moisture coming through the grout from behind carrying minerals with it. I'd start looking at the expansion joints on the deck nearby, maybe they're leaking and allowing the ground below to get saturated. Any changes to the landscaping/planters/sprinklers just before it started happening? Sealing the surface it's leaching out of is not going to be any more effective that taping over the outside of a leaking hose. Eventually the water will find a way through.
    Mar 2007
    San Rafael, CA USA
    12,082
    You mean "efflorescence".
