Thread: how to back wash when filter does not have rince position
    Hi there, I have a sand filter who have only 5 positions (filter-winter-recycl.-back wash-waste)
    I want to know if I'am correct when doing back wash... After I run back wash for 2-3 minutes, I switch to "waste" mode for 30 seconds, before returning to filter... Am I correct doing that ?
    Should I use recycl. position instead ???
    thanks
    12' above ground pool install "inground" - hayward pro-lx serie sp-2295 pump - hayward vari-flo sp704 - 2 x 4' x 20' fafco solar bear panel
    for polar bear living north pole, Quebec city , Canada
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: how to back wash when filter does not have rince positio
    No that's fine. Recycl is recirculate and bypasses the sand entirely.
    Jun 2007
    New Jersey
    653
    I had one of those from about 1960 to 1975 (one of the first MPV's--solid bronze case and brass moving parts). Waste does not reach the sand, either. Only thing it will rinse is the MPV itself. I would just give it a few seconds on Waste or go straight to back to Filter (what we did for fifteen years).
    I think the rinse position was invented only after they went to plastic MPV's. The cheaper material allowed a bigger, more complex valve with more positions. Ours was a 4-way: Closed, B'Wash, Filter and Waste. It was a big step up from just opening and closing gate valves.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    38,252
    There is no point in using the waste or recycle function in the backwash process since the water will not be moving through the filter.
    Just alternate between Backwash and Filter a few times ... well that is what I would do with a DE filter, the alternating may not be needed for a sand filter.
