Thread: Lost some sand..
    Apr 2012
    South Dakota
    87
    Lost some sand..
    I opened the pool tonight and I started out on waste to dump the antifreeze out the backwash hose then I think I made the mistake and ran on backwash for 30 seconds and I lost a couple pounds of sand. Should I pickup a bag of sand and top off the filter?
    Thank you
    18600 Gallon In Ground
    Vinyl liner
    Aqua Genie Skimmer/Return
    Purex Triton Challenger wet end with Emerson 2EZ Speed Two-Speed with Timer Motor 3/4HP #EB2980T
    Sta-Rite 145361 Cristal-Flo II High-Rate Sand Filter 22Inch
    Taylor K-2006
    DCAG's Avatar
    Jul 2009
    Merrimack, NH
    95
    Re: Lost some sand..
    There's 250 pounds of sand in your filter, so if you lost a couple... don't worry about it.
    Dan
    16' X 24' Wilkes Pools "Genesis", 10K Gal
    Hayward Powerflo Matrix 1 hp, & 18" Pro Series sand (S180T)
    Apr 2012
    South Dakota
    87
    After dumping the antifreeze to waste should I have just switched it over to filter? Not sure why I started backwash since it was done before I closed it.
    Vinyl liner
    Taylor K-2006
    DCAG's Avatar
    Jul 2009
    Merrimack, NH
    95
    Even switching to backwash, you should not have lost more than a couple teaspoons worth of sand. When you backwash, does sand continuosly come out with the water? If so, that would indicate a problem.
    When you said a couple of pounds I envisioned the amount of sand you could hold in two hands...
    Dan
    Apr 2012
    South Dakota
    87
    I would have to backwash again to test. Reevaluating again may 5lbs but nothing more.
    Vinyl liner
    Taylor K-2006
