Thread: PoolSean help or anyone out there! Clean/Chek cell dig 220 A
    Last year I wqs having problems generating chlorine and thought the cell was bad as I was getting no amps etc on my test screen. Bought a new cell size 42 from y 34,500 gallon pool. Turns out it was the control box. So I switched to chlorine and ran the rest of the summer. This year we just bought a new Dig 220 Auto pool pilot box. I got it all hooked up and get the check/cell warning light. Not sure if it matters or not but the dig 220 box did not have a cell size 42 at set up just 36 and then to 48. I set it back to size 36 instead of 48 and seems to have taken care of the check/cell light.
    Is there something else that could be wrong or was that it. What should I do next. My volts 19 amps 11.4 Water temp is 60 and purifier is set at the max now at 31% Salt level is at 3,800 or so it says I have not got a real good test yet but the strip and box say about the same thing
    Thanks
    18x36 Rectangle dual drains in floor
    Digital Autopilot SWG
    AqualCal Heat Pump
    1.5 Horsepowered pool pump
    Re: PoolSean help or anyone out there! Clean/Chek cell dig 2
    Also I have it on power level 1. Thanks everyone!
    AqualCal Heat Pump
    my bad. i have a 24,200 gallon pool
    AqualCal Heat Pump
