Thread: Fixing uneven spots in Intex 16x48
    My pool was up for 2 years and it started to develop little dips here and there. We put 1" foam (pink stuff) under it when we put it up. I took it down before winter this year and getting ready to put it back up. The ground is completely level, there was no more than a 1/8 inch difference in the water level all the way around. For the areas where where the dips are at should i use sand or topsoil to re-level keeping in mind there will be foam board on top of it. There would be no more than 1/8-1/2" of material added. Also should the foam board be replaced?
    poolnew-b's Avatar
    Jul 2010
    laconia, NH
    131
    Re: Fixing uneven spots in Intex 16x48
    If it was me and I was using foam insulation I would just use which ever is easier to get and then tamp it real good.
    As far as replacing foam goes. If it smells or is damaged badly I would change it, if not just reuse what you have.
    Intex Ultra frame 16x48
    Intex 1600GPH Sand Filter
    Taylor K-2005 test kit
    Thanks, I was thinking the same thing.
