Results 1 to 7 of 7
Thread: BJ's Winter Heat Pure Ice Melt to Raise CH?
    Jul 2009
    Long Island, NY
    267
    I bought a 50 pound pail of Berkley & Jensen (BJ's) Winter Heat Pure Ice Melt hoping that I can use it to raise CH. The label states that it contains pure calcium chloride pellets. The CAS number is 010043-52-4. I looked at the BJ's website but could not find an MSDS sheet for the product. I think it is manufactured for BJ's by Scotwood Industries because I found what appears to be a product with the same name on their website. Their MSDS sheet shows it to contain 90-97% Calcium Chloride, 1-2% sodium chloride, 0-1% strontium chloride and water.
    Is this safe to use in my pool to raise the CH?
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    Jul 2009
    Long Island, NY
    267
    Re: BJ's Winter Heat Pure Ice Melt to Raise CH?
    Anybody have an opinion on this?
    Jul 2009
    Long Island, NY
    267
    I received a copy of the MSDS sheet from BJ's and it lists the following chemical analysis:
    Calcium Chloride (CaCL2) - 94% Min, 94% typ.
    Alkali Chloride (as NaCL) - 5% Max, 4% typ.
    Magnesium (as MgCL2) - 0.02% Max, 0.01% typ.
    Other impurities (except moisture) - 0.20% Max, 0.10% typ.
    So, based upon this information, is this safe to use to raise the CH level in my pool?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    Leslie's Hardness Plus MSDS reads
    Calcium Chloride 10043-52-4 > 94.0 - < 97.0%
    Potassium Chloride 7447-40-7 2.5%
    Water 7732-18-5 > 0.0 - < 2.0%
    Sodium Chloride 7647-14-5 1.5%
    I wouldn't hesitate to use it. But why would you want to? Your vinyl-lined pool doesn't care about low Calcium. Warranty or something?
    Jul 2009
    Long Island, NY
    267
    Richard,
    Thanks for the reply. Yes, it's a warranty thing. I am going to raise the CH up to the minimum for my equipment until the warranty period is over. The only way that I'll do it is if I can use the 50# bucket of ice melt that I bought at BJ's. There's no way that I'm going to pay pool store prices for hardness increaser.
    I just want to make sure that the other ingredients (besides calcium chloride) listed are safe. I'm looking for the chemical experts here on TFP to bless this prior to dumping it in my pool.
    Mar 2007
    San Rafael, CA USA
    12,082
    The BJ's Winter Heat Pure Ice Melt should be fine to use. I assume that the 0.2% of other impurities do not include lots of metal such as iron. Even if you were to add 200 ppm Calcium Hardness (CH) with this product and that the 0.2% were only pure iron, that would be 0.44 mg/L of iron. I doubt very much that all the impurities are iron and maybe none of them are so I think the product is fine to use.
    Jul 2009
    Long Island, NY
    267
    chem geek,
    Thanks for the 2nd opinion.
