Thread: Newly opened green pool -need to backwash filter every hour?
    I just had my pool opening today (in-ground, DE filter). My water is dark-green, as it usually is when opening. Is it normal for me to have to backwash my filter & change my DE every hour while he water is this dark? It seems every 45mins-1 hour, the PSI gets high (or gets extremely low as the pump isn't drawing much water). Back washing fixes it, but then I have to do it all again every hour. I just want to make sure this is ok & that I'm not hurting anything. Thanks!
    30,421
    Re: Newly opened green pool -need to backwash filter every h
    Welcome to the forum. Yes, it is common. Your water is filled with a lot of junk and your filter is catching it. As you continue shocking, the time between backwashes will increase as the water gets cleaner.
    You are shocking, correct?
    Yes, I am! Glad to know that it's normal & not just me losing my mind.
    Thanks for your help!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, suz414
    By the way, we recommend backwashing when you filter pressure goes up 25% from the clean filter pressure. You don't really want the filter to get so dirty the flow is greatly reduced. What is your clean pressure reading?
    38,290
    Just to be sure, you have read these correct and this is the shock process you are going through?
    Defeating Algae
    Turning Your Green Swamp Back into a Sparkling Oasis
    Shocking Your Pool
    mas985's Avatar
    Pleasanton, CA
    11,737
    It might be a little easier to put the filter in recirculate mode until all the algae is dead and on the floor of the pool. Then you can vacuum to waste. Hopefully this will save a lot of DE.
    Mark
