Results 1 to 7 of 7
Thread: Solar Fish Question
    Solar Fish Question
    Couple questions on these..
    First off, ya I got them I wanted to try them since it seems to be split 50\50 if they work well.
    My pool is about 950 sq. feet for those of you that have them.. Should i stick 2 turbos in there?
    Also, do you guys take them out during the day or just leave them in there 24/7?
    Should I be able to feel the little motor running all the time?
    Thanks for the help
    DrDave
    http://plansbyjorde.tripod.com
    Necessity is the Mother of Invention
    Oct 2007
    Valrico, FL
    542
    According to the literature for these one fish is good for about 400 sf. So you will probably need two of them, both with the wire cut. They need to be in the pool 24/7. The pump only runs for a short time every few hours. And then only when in the water. They have a sensor that detects when the fish is submerged in water.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Ok thanks.. The package says cut the wire if its over 400 ft (The turbo) so you think i need 2 still?
    ****, I beat the **** out of mine today thinking it was bad since I didnt hear the motor running. Is there anyway to tell if the thing is still working?
    DrDave
    Mar 2007
    Morris, IL
    477
    If at first you don't succeed, beat on them some more. I would get a bigger hammer. lol
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Oct 2007
    Valrico, FL
    542
    Remove the fish from the water, leave out for a while. Then place back in to the pool holding it by the pump housing. You should feel the pump run for a few seconds. If not, the batteries are dead. Cut open the plastic and dump the liquid into your pool.
    If I cut open the plastic and dump the liquid into the water, how long will that last? Its day #2
    How long should i keep it out of the water for?
    Attached Files Attached Files
    DrDave
    Thanks that worked..
    DrDave
