Thread: CLE Ohio pool install?
    Hi! Im long time lurker, first time poster. Finally after years of asking for a pool, my husband finally caved
    Hoping someone can help me out. I have been doing quite a bit of research on IG pook kits.
    Questions:
    1. Should I purchase a kit and have someone install it? we are looking at doing a paver patio as well. Does anyone know a pool installer in the cleveland ohio area...that doesn't care if you purchased to pool online? Also, is there one company that does both, patio and pool, or should I seperate the projects?
    I want to try and save some money and figured if there was an independent installer, they would most likely have better rates...i have no idea.
    2. Or should I just go with a company and purchase the pool and have it installed...not sure if this would be more, but I am heading out later today to visit a few places to look around and see what I find out.
    Any help would be appreciated!
    Pool: 18000 gal w/ spill over spa Pump: 3HP Intelliflo VS 011018 Booster: 1.5HP Sta-Rite Dyna-Max Filter: 300 sqft Sta-Rite System 3 Heater: Rheem RayPak 399 BTUH Chlorinator: ClevaChlor RP30HD Controller: Jandy iAquaLink RS PS8 PDA Cleaner: Pentair Pool Shark Plumbing: 2"
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: CLE Ohio pool install?
    Welcome to tfp, plunging
    I love your username
    I can't really answer you questions, since I do not have direct experience. But if you use the google search at the very low left of each page, there are many examples of projects using kits.
